Compare 2 images in Labview
Hello, Everybody.
How can I compare 2 visualization graphic in LabView ?
For example on the first image is the lamp switch off, it seems a red colour, in the second picture is the lamp switch on, it seems to be a green color.
How can I with LabView automatically compare these 2 images / this color change? Through pix compare? How can I position the right place, that this color change appears???
Thanks a lot.
Johnny
(6,224 Views)
Seems you are searching for functions in the vision toolkits for LabVIEW. http://www.ni.com/vision/vdm.htm
André (CLA, CLED)
(6,213 Views)
The IMAQ-Vision module is a full blown machine vision library. If you just need to compare two pictures, you may also convert them to 2D-Arrays and subtract one array from the other. The resulting array will dontain the differences of the two images.
Kind regards,
Jochen Klier
(6,180 Views)
Thank you for your tipps, I will try to make that.
Regarts,
Johnny
(6,151 Views)
