Compare Traditional DAQ with DAQmx (Analog Input)
Hello
If assume the AI Acquire Waveforms VI same as DAQ Assistant, How we should specify an acquisition mode to N sample or continuous sample.
Thank you for helping,
(3,399 Views)
Hi Pattra,
you should replace AIAcquireWaveforms by DAQmxRead function!
There are other DAQmx functions where you define those settings, like DAQmxTiming. You need to specify those parameters as was done in that very old original software you are trying to upgrade!
See this for more detailed information!
(3,373 Views)
Thank you again for your advice.
But I am still confused about that. I attach pictures of tradition  code. Could you change for me to DAQmx code that I am not sure about specification to N sample or Continuous sample.
(3,359 Views)
Hi Pattra,
How should I do this? Should I use GIMP to paint in the image?
When you want to have code you should attach code (aka VI)!
The sample reads just 1000 samples at 1kHz samplerate: why do you want to read "continuously"?
Btw. LabVIEW comes with a huge library of example VIs, explaining how to use all those functions. There are a lot of VIs explaining how to use DAQmx functions. Just examine and try them!
(3,354 Views)
