Connecting CB68-LP card to PCI 6220 card
I connect PCI 6220 card to CB68-LP. Than I want to bring sine signal on the CB68-LP and simply watch that signal on screen with NI LabVIEW. Can anyone tell me which pins to use on CB68-LP card to bring that input sine signal. Or simply is there any explanation for all these pins, where is pin for input signal, where is GND...? Thanks a lot for an answer.
(3,145 Views)
Hi tonci,
there's a user manual for the PCI6220, it explains those pins. Your CB68 simply allows to connect to each pins with a screw clamp…
Additionally you can create DAQmx tasks in MAX and you get wiring diagrams for free!
(3,135 Views)
