Compare set values 1D-Array
Sorry I have two array 1D with a column of unique numbers respectively. The column in first array does not change, the column in second array  contains part of the data of the first array or a lower number of elements. I should look for the missing elements in the first column in a new array (result).
example:
1^ array           2^array                    result array
3,4,1,2,5             4,2                              1,3,5
Could you please help me?
Message 1 of 14
(5,157 Views)
Accepted by frank22
Hi Frank,
Look for the existing elements!
Pick first element from array2, search for it in array1. If found, then delete it from array1.
Do the same for the 2nd element of array2.
After checking all elements from array2 only the "missing elements" will remain in array1!
All you need is a FOR loop, a shift register and the Search1DArray/DeleteFromArray functions…
Message 2 of 14
(5,146 Views)
I thank you for the valuable information, I wouldn't know how to delete the element from the first array but now I'll try. Could you send me an outline of how you thought about doing? I would be grateful
Message 3 of 14
(5,135 Views)
Accepted by frank22
Hi Frank,
Like this (pseudocode):
FOR each element in array2
  index := Search1DArray(array1, element)
  IF found THEN
     DeleteFromArray(array1, index)
  ENDIF
NEXT
MissingElements := array1
 Your requirement is a nice way to actually learn LabVIEW and some of its features.
Show what you have tried so far and we will give suggestions on how to improve it!
Message 4 of 14
(5,126 Views)
other the error on the right related to the size of the array I think there is more to do.
Message 5 of 14
(5,112 Views)
Accepted by frank22
Hi Frank,
did I mention any BuildArray function before?
Just a shift register, Search1DArray and DeleteFromArray:
Message 6 of 14
(5,084 Views)
Lucky Frank, now you did his homework...
Greets, Dave
Message 7 of 14
(5,080 Views)
Thanks you very much.
Message 8 of 14
(5,070 Views)
Because it does not work?
Message 9 of 14
(5,012 Views)
Attach your VI and not a picture.  We can't debug pictures.
I'm suspicious of 2 things:
1.  You are working with strings and not numbers.
2.  Both of your input arrays have what appear to be empty strings as the last element.  While I'm not sure how that would cause element "2" to appear, dealing with strings and empty strings certainly wasn't part of your original problem description.  Perhaps one of those "2" 's is not just a "2" but has a space or some other hidden character in it.  For example, if you are searching the array for "2{space}", it certainly will not find a match with "2".
Message 10 of 14
(4,999 Views)
