Comparing Clusters with NaN elements
@paul_a_cardinale wrote:
This works for any cluster:
Once a NaN is packaged in a variant, the rules about comparing NaNs are no longer applied; all NaNs are considered equal.
However this could be construed as a bug, and may be 'fixed' in the future.
I gotta see that more closely.   Could you please elaborate!  (Don't make me actually boot up the laptop - I honestly haven't even opened LabVIEW for over a year)
Message 21 of 26
(2,028 Views)
@softball wrote:
Hi Paul
You are right, and you are wrong.
'To Variant' works like 'Flatten To String'. It converts a NaN to a representation that can be compared directly.
However, if the NaN's involved are binary different as shown in the case above then a NaN comparison will still fail.
But interesting. Maybe a 'To Variant' is faster than 'Flatten To String'.
Regards
What's the bottom ÷ for? The output is not wired.
Message 22 of 26
(2,025 Views)
Hi
Sorry for confusing you. Just ignore the ÷. It isn't connected to anything as you noted. Just me being lazy when generating the example.
Regards
Message 23 of 26
(2,018 Views)
Accepted by littlesphaeroid
@softball wrote:
Hi Paul
Regards
Good catch.
Flatten to XML works with any NaN.
Message 24 of 26
(1,999 Views)
Hi Paul
Brilliant !
Different NaN values get converted to a generic 'NaN' string. Just like we want it.
Regards
PS : This behavior would be a nice candidate for a LabVIEW ini setting.
PPS : Except it would encourage some to compare floating point values for equal or not. Which is a bad idea.
Message 25 of 26
(1,980 Views)
This has been a very interesting conversation. Before reading the last few entries I also tried the flatten to string comparison, and for my purpose it works, since I'm comparing two versions of the same (complex) cluster, and whose NaN values haae the same origin. It does sound like flattening to XML is even more reliable.
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 26 of 26
(1,958 Views)
