Comparing strings of GPS data? Any Sub VI's?
Does anyone have any idea how to compare strings of GPS data and move a stepper motor from the comparison results?
(2,567 Views)
Depending on what you wanted to compare I am sure you could write a VI in LabVIEW that would do it for you. There are several string manipulation functions available on the string palette. As for the stepper motor, you might consider posting this part of the question to the motion section of the forum.
(2,567 Views)
