Thanks Ben
The board is definitely supported.
The code that works is quite straightforward.
The issue is that the channel wizard seems to skip a step. From within my VI, I select PROJECT>>DAQ CHANNEL WIZARD. The channel wizard window comes up as expected. When I click on NEW, the "select a channel type to configure" dialog should come up. Instead it goes directly to the analog input configuration window.
I've reinstalled LabView, no change in this behavior. I can perform all types of I/O by configuring in the VI, but I'd really rather use string control, so naming channels in the wizard would be nice.
An light you could shed on this would be much appreciated.
