Comparison Palatte Equal? Not working
I have an Equal Comparison as a condition for a while loop. I probed the leads and they are equal however the output is false and the while loop continues to execute. I tried to typecast one wire to the other incase that was a problem(one being a numeric and the other a signed numeric) still not working. Please help?
-Nate
Message 1 of 11
(5,855 Views)
Accepted by N8D11
The equal function will work as long as you don't do some silly thing like comparing floating point numbers. If you are, you should do a search for this extremely well discussed subject.
Message 2 of 11
(5,853 Views)
Do you have any screenshots or the VI that you can attach?
I have found the equal function to be very specific and even something like an extra space would cause it to not be equal (at least for strings).  Make sure you are sure of what you are comparing.  Is there a different way you could check for comparison?
Message 3 of 11
(5,843 Views)
Message 4 of 11
(5,829 Views)
I m facing a similar problem using comparison palette Greater than equal to and Equal to. Two same values when compared, the output is false. Please find the example vi attached and help!
Message 5 of 11
(5,573 Views)
Precision...
Jim
Message 6 of 11
(5,557 Views)
There is no such thing as "Equals" when dealing with floating point numbers.  The best you can do is an "approximately equal" by subtracting the two values and making sure the difference is less than whatever precision you want.
Message 7 of 11
(5,548 Views)
'subtracting the two values' --> don't forget to get the absolute of the difference before you compare to your tolerance limit... 😉
QFang
CLD LabVIEW 7.1 to 2016
Message 8 of 11
(5,522 Views)
Thank You for your help. The precision and taking its absolute value solved my problem. 🙂 🙂
Message 9 of 11
(5,484 Views)
Yup here is a made VI that is pretty much this.
https://lavag.org/files/file/259-floating-point-almost-equal/
Message 10 of 11
(5,431 Views)
