06-06-2012 02:23 AM
I know that I have to install the corresponding RTE version to my EXE-Files, but I'm not quite sure if it's also necessary to do this if only the version changes from LV xxx to LV xxx SP1?
I tried run a project written in LV 2010 SP1 with the LVRTE 2010 and it worked, but my colleague did this with his project had the message that he had to install the correct RTE...
Do I have to update every computer to LV RTE 2010 SP1 to avoid problems? Many thanks in advance!
06-06-2012
02:55 AM
- last edited on
09-02-2026
01:36 PM
by
Content Cleaner
With a search at ni.com you will find:
Which Run-Time Engine Do I Need for My LabVIEW Application Builder Executable?
Christian
