Compatible with VIA CPU?
Is Labview / DAQmx compatible with VIA CPUs? Does it work "out of the box"? I am interested in using a Labview executable in Windows, developed on a different machine.
(3,043 Views)
Accepted by fborlc
Hello fborlc,
Though we haven't tested with VIA CPUs, it should work as long as the CPU meets the LabVIEW and DAQmx system requirements.  These requirements are documented here:
https://download.ni.com/support/softlib/multifunction_daq/nidaqmx/9.5.1/readme.html
Do you have any specific worries for using LabVIEW with a VIA CPU?
Patrick W.
Applications Engineer
(3,009 Views)
Thanks Patrick. No specific concerns, just wanted to be sure I wasn't on a fool's errand. The Runtime system requirements are just what I was looking for.
(3,004 Views)
