Compilation Stuck at Placing and Routing
Would really appreciate help with an issue I have.
I am using a cRIO-9074 and programming it with LabVIEW 2015. Now that I have started to add more code onto the FPGA, the compilation just hangs at "Placing and Routing". I have let it run overnight to come back in the morning to see the time elapsed is over 10 hours. The operating system is Windows 7 with an i5 processor. Any help will be appreciated.
Message 1 of 9
(6,079 Views)
That usually happens when your design is on the border of being able to fit in your FPGA. You'll benefit from optimizing your design or buying a bigger FPGA.
Message 2 of 9
(6,056 Views)
use NI update service to check for the latest updates
Message 3 of 9
(6,027 Views)
Hi anzarc,
which OS are you using?
I hade the same problem on a Win7-32bit-OS with 4GB RAM: this wasn't enough for the Xilinx compiler.
After changing to a computer with Win7-64bit-OS (and 8GB RAM) all runs well.
You can also use the compile farm service from NI! (You do have a SSP, don't you?)
Message 4 of 9
(6,016 Views)
I am actually pretty new to LabVIEW and FPGA. How would you check if your design is getting too large for your FPGA system?
Message 5 of 9
(5,985 Views)
Hi anzarc,
before the "placing and routing" step you get estimations on resource usage…
Message 6 of 9
(5,960 Views)
you either wait for the compliation to return a error or Analyse the results of the Estimated Resource Usage.
In the ERU Results if your code uses more than 99% of slice LUT, then the compilation will not succeed.
Am pretty sure that its the code needs to be optimized, i have used the compiler with many Windows OS and with 4gb RAM too, it takes time but go through.
Regards.
Digant Shetty (LV 18.0)
AE, Combined Digilog Systems Pvt. Ltd.
Message 7 of 9
(5,947 Views)
As the others have stated - optimising your code is by far the best way to - if you google for 'Advanced FPGA Throughput' I think there's a PDF that goes into detail about how to optimise FPGA code to reduce resource usage etc.
There is a way to significantly reduce FPGA compile times though if you have a fairly modern CPU: http://forums.ni.com/t5/LabVIEW-FPGA-Idea-Exchange/Multi-core-Compiling/idc-p/2301338#M297
(blog)
Message 8 of 9
(5,927 Views)
Thanks for the answers.
The pre-syntiesis estimation shows the slice LUTs at 57%, but after the synthesis step, it jumps to 87%. I see how 99% is high, but should it be giving me problems at 87%?
Thanks again for the help!
Message 9 of 9
(5,876 Views)
