Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Compile error (Code could not be generated)
Hakan L
Member
10-27-2004
09:21 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
When I try to run the attached vi I get the following error message "Code
could not be generated correctly for this VI."
I use Labview 7.1 under Windows XP.
ParSettings.zip 293 KB
0
Kudos
Message
1
of 2
(2,801 Views)
Reply
Re: Compile error (Code could not be generated)
Hakan L
Member
Author
10-28-2004
06:40 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The "Representation" enum is defined differently in the "SDO Par In", "SDO Par", PDO Par In" and "PDO Par" clusters. Labview does apparently not recognice this and crashes instead of warning for incompatible data types.
0
Kudos
Message
2
of 2
(2,801 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
