Compiler Error with simple vi using MatLab script nodes
While attempting to build a simple vi to test the capabilities of LabView's interface with MatLab, I received a compiler error message that said I should report the problem to National Instruments Tech Support. The error said, "reference to undefined label from: refPC=0x41C." I've attached the vi that created the error. I am using LabView 7.0 on a PC running Windows 98.
(2,840 Views)
I don't know if this will help your problem, but there is a fix for some problems with LabVIEW 7.0 and Matlab:
http://digital.ni.com/public.nsf/websearch/4475BC3CEB062C9586256D750058F14B?OpenDocument
Good luck,
-Jim
(2,840 Views)
