What does "Remote Panel protocol version incompatible" mean?
My LV server (LV 7.0, Win2K Pro) has a remote panel.
My remote computer (LV 7.0 RTE, WinXP) gets
this message "Remote Panel protocol version incompatible". The SAME remote computer CAN see a remote panel from another machine.
(3,358 Views)
do you get the message with any VI from the server or is it just the one? Do you install beta LabVIEW software on the machines? Can the third machine see the VI from the server?
(3,358 Views)
Ahh. I found the problem. I was using the html that I had generated with LV 6.1.
I got a hint when I made a simple vi in LV 7.0, saved it to disk and it worked OK. Then I saved the other remote panel to disk, grabbed the gust of the html out of it and poked it in the desired target html and it worked.
JIM
(3,358 Views)
