picture on excel using ActiveX
I tried to put a jpg picture on excel along with some other information (string format). I want to use activeX because I don't have report generation toolkit for MSOffice. I read in the discussion forum about the way to put jpg on excel (someone else has the same question as me), it said I should make a shape object and select addpicture method, but I do not know how to get a shape object. Does anyone know how?
(3,069 Views)
There is no need to flatten the image to place the picture as a shape in Excel. The AddPicture method takes the JPG filename as an input.
From the Excel.Worksheet wire:
Property Node, select Shapes
cascade into Invoke Node, select AddPicture
From there you can specify the filename and location on the worksheet. This will add the picture as a new shape to the worksheet.
Michael
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(3,069 Views)
