Compiling a model in MathWorks
We are trying to compile a Model in MathWorks Simulink software.
An error occurs in the building part after setting it according to the tutorial.
How can I solve this?
The link below is what I referenced.
(1,945 Views)
Hi there,
Try uninstalling all the frameworks & runtimes  and install original .NET4.0 before being able to install SDK, and then reinstall all that stuff. I'm using R2016a, because I think it's the latest version compatible with VC2010 32 bits DLL code generation.
Also, to verify that the compiler has been installed, type in the Matlab Command window:
mex -setup
Matlab should reply:
MEX configured to use 'Microsoft Windows SDK 7.1 (C)' for C language compilation.
Let me know what happens with you 🙂
Best,
(1,835 Views)
