How to use 'EvaluateEx' function from the TS API
I am using the labview example of how to build a sequence from an XML file, I modified it so I can create a test in excel and then convert it to a sequence.
I can set all the parameters but I'm struggling on how to set:
- Numeric format when performing a numeric limit test, in teststand this can be done with step.result.numeric.numericformat, but how do I do this with 'EvaluateEx'
- How can I fill in the parameters when calling a labview adapter and subsequence.
I'm using labview and teststand 2016.
Message 1 of 1
(1,172 Views)
