Compiling a vi with link to dll => error 7 "source does not exist"
I'm trying to compile a vi using Application Builder. The vi contains a link to imaq.dll (a part of the NI vision pack).
When I try to build, I get the error
"Error 7 occured at Imaq.dll - source does not exist"
But the source does exist, and it is not hidden, read-only or blocked by security policies.
Why does Application builder refuse to see this file ??
I tried copying the file to the base dir of the vi, and added it to the build from there => same problem.
System:
LabView v. 6i
Imaq v. 2.5
Windows NT4
(2,619 Views)
Hi Angelo,
If the vi is working properly under LV, then you can try to register the IMAQ.DLL
Execute the following command:
REGSVR32 "the complete path of IMAQ.DLL"
You should get a message that it has been registered; then try again.
Good luck,
Alberto
(2,619 Views)
