Complex Bessel functions in LV 2009?
Can anyone please clarify whether the Bessel functions in LV 2009 operate on complex inputs and give complex outputs? The "Help" text mentions only real outputs.
A quick test on the Bessel function Jv of zeroth order seems to indicate that it accepts a complex input but delivers a real output. Does it just ignore the imaginary part of the input?
Any input much appreciated, thanks!
Peter
(4,275 Views)
Hi Peter,
The Bessel function in LabVIEW 2009 can not operate on complex input. If you specify a complex input, it will be casted to real. You should see a red dot which indicates the cast.
(4,263 Views)
Accepted by Peter Dias
Hi ttrr
Many thanks for your prompt and helpful explanation. I thought something like that was happening, your confirmation much appreciated.
The only viable solution I have found is using Matlab (Excel BESSELJ cannot handle complex inputs either).
Regards
Peter
(4,254 Views)
Hello Peter,
LabVIEW MathScript can support real-order Bessel functions with complex inputs.  Reference the help for the bessel_j function, in particular.
Grant M.
Senior Software Engineer | LabVIEW MathScript | National Instruments
(4,233 Views)
Hi Grant
Thanks for your input. Using the LV MathScript add-on is definitely an option from the cost point of view. You tip much appreciated!
Regards
Peter
(4,201 Views)
