Complex numeric display format
Hi all,
By default when we drop a complex numeric indicator (CSG, CDB or CXT) it displays the complex number are Re/Im
Is there a way to change to display format to display the complex number as r/theta?
Cheers
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,901 Views)
I don't think so, but you can always use a string indicator and do whatever you want with the parts. 😄
Or even do degrees. 😉
(3,894 Views)
Ah well... Thanks for confirming what I was fearing.
I'll check if there is not already an idea in the exchange for this, and post one if not.
Epictetus
Antoine Chalons
(3,883 Views)
Of course having a complex control with R/theta is a bit more complicated.
On a tangential discussion, complex numbers are always internally represented as two floating point values RE/IM, while under certain applications it would be more useful if these two numbers would represent R/theta. Imagine that the complex number represents the direction and speed of a vehicle. As soon as the vehicle stops temporarily (speed=0) all direction information is currently irreversibly lost (RE=IM=0), even though it is still pointing in a very defined direction. With R/theta, the direction could be maintained. Currently, we need to program around that :).
(3,882 Views)
I doubt that LabVIEW would invent its own formatting codes. It might be worth searching the web if there is already prior art in other programming languages.
(3,878 Views)
Hehe
My use case is more power grid than navigation, but yes, it would be helpful.
Epictetus
Antoine Chalons
(3,875 Views)
