Compound arithmetic OR issue...
Why?
(4,213 Views)
Accepted by topic author abeaver
I can't see because the probe bubble is in the way, but is the output inverted?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,211 Views)
You can see the invert through thebreakpoint bubble
(4,207 Views)
To add a bit more detail... if there's a little circle in the middle of the output, then the output is set to be inverted. You can un-invert it by right-clicking on it.
(4,205 Views)
OK, so it's the input that's inverted, not the output, but Mike was right. If you invert the inputs, then false becomes true, and you get exactly what you're seeing. Why are those inputs inverted?
(4,199 Views)
Yes, Mike was correct. The output was inverted! Thanks a lot.
(4,194 Views)
