problem softmotion
I am actually on a project that consist of controlling the motions of a solidworks assembly using softmotion module. I followed the instructions as they are, listed in the manual and posted in forums and youtube videos and I am pretty sure that I was doing the same. The problem is sometimes it works and sometimes id does not. And if it does work, it will never do that again. One of the examples was acting verly wierd, I did a lot of copies of it, when I execute for the first time, it does work but when I save befor closing it will never works (when I open it for the next time). When I close without saving, it works for the next time I open it. Note that when I execute, the solidworks starts to simulate (in a pirode of one hours as it is configured), but no motion happens.
I am using labvien 2013 and solidworks 2014 (please dont say to me that the reason is because solidworks is newer then labview because I tried with solidworks 2012 and the same problem happens).
Thank you for your help. Have a nice day.
(2,855 Views)
Were you able to run any of the built-in shipping examples of the SoildWorks integration? If some of the shipping examples are not compiling correctly, there could likely be a software versioning issue. Regardless, the best place for this question may be on our motion control forums or the virtual prototyping community page. Finally, have you looked through our White Paper on the SoftMotion for SolidWorks? I have copied it's link below.
https://www.ni.com/en/support/documentation/supplemental/09/ni-softmotion-for-solidworks---faq.html
(2,816 Views)
