Computer pause every 2 seconds while writing to hard drive.
What USB device are you using?  And what format are you saving your data?
GCentral
Message 11 of 16
(830 Views)
The USB device I'm using is a custom device that I designed.  The data format is string.
I managed somehow to put together a producer/consumer arrangement and that seems to have fixed the problem.  Can't believe it works, considering it's my first time and the code wasn't designed that way.  Anyway, some questions come to mind.  When I first start this off, I create a queue for the application.  For as long as the app runs, it is running in a while loop that is now designated the producer loop.  When recording, It is putting data in, and my consumer loop is taking it out.  First off, is there any chance of this causing a memory leak?  Second, is there a way to purge the queue at the start of recording so I know I don't have any old data in there?
Thanks for the heads up on this approach.  It has been a great help.
Message 12 of 16
(814 Views)
I found a flush queue vi that should be useful for flushing/purging the queue, so I should be good there.  I just want to make sure I'm not gonna create a memory leak.  If so, what safeguards do I need to implement?
Thanks.
Message 13 of 16
(809 Views)
I guess I would put an upper limit on the buffer just in case something happens and it gets stuck, you won't run your PC out of memory.
Bill
CLD
(Mid-Level minion.)
Message 14 of 16
(804 Views)
Ok, I'll do that.
Thanks to everyone that contributed.  All working now.
Message 15 of 16
(793 Views)
It's easy to START with a producer/consumer architecture - it's a whole different story to convert existing code!  Very nice!
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(774 Views)
