Concatenate 2d arrays
Kind of a noob here. So here is what I want:
All 2d arrays -
Array 1: Array2: Appended Array:
0,1,2 6,7,8 0,1,2,6,7,8
3,4,5 9,10,11 3,4,5,9,10,11
So I know I can do this by indexing both input arrays and then appending them and then build another 2d array. My question is, is there a way to do this that is nice and neat and not so convoluted?
Thanks for any help.
Message 1 of 15
(17,459 Views)
Duplicate post.
Please do not ask the same question twice. Have a little patience.
EDIT:  It appears this may have been an automatically created thread due to it being moved from the LabVIEW Idea Exchange where it was originally posted. In that case, please disregard my comment regarding the chiding on the patience. It's still wise to have a little patience in general, though. Smiley Very Happy
Message Edited by smercurio_fc on 12-11-2009 09:27 AM
Message 2 of 15
(17,389 Views)
Cant you just use Build array but r-click it for concatenate inputs?
Else you can use Insert into array and add after the last column i s'pose.
Or you can transpose both matrices and build array and transpose back ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 15
(17,369 Views)
/Y
If you check out the other thread you'll see the solutions posted. Smiley Wink
Message 4 of 15
(17,350 Views)
I also have a question. Concatenating 1D arrays works fine
1,2,3,4  concatenated with 5,6,7,8,9 gives 1,2,3,4,5,6,7,8,9
but with 2D arrays
1,2,3,4
5,6,7,8
concatenated with
10,11,12
20,21,22
gives
1,2,3,4
5,6,7,8
10,11,12,0
20,21,22,0
Why not
1,2,3,4,10,11,12
5,6,7,8,20,21,22  ?
Message 5 of 15
(16,298 Views)
Attach your code.
There are several ways to concatenate, maybe you want to transpose first, for example, or wrap a FOR loop around it.
Message 6 of 15
(16,287 Views)
Transpose before and after concatenating.
/Y
Qestit Systems
Message 7 of 15
(16,274 Views)
Fun with transposing arrays.  Can't count how many times I've had to do this for table displays...
Message 8 of 15
(16,271 Views)
Here's the second method I suggested, same difference: 😄
This seems cleaner, but I am not sure what's more efficient....
Message 9 of 15
(16,252 Views)
Some people might try to suggest that you can do more with less code.....
Message 10 of 15
(16,240 Views)
