Concatenate Elements of a 1D array
Fairly simple question I'm just looking for an efficient way to do it.
I have a 1D array of HEX values and I would like to be able to combine 2 elements into 1 through out the whole array.
Ex: elements[0] and element[1] become element[0]. element[2] and [3] become element[1] etc.
EDIT:
I have attached an image to show what I am doing. I take a string, convert to hex and then into a 1D array. But ultimately I need to convert 2 ascii character into 1 hex! As of right now I have 1 ascii gets converted into 1 hex.
Thank you!
Message 1 of 14
(10,168 Views)
Decimate1DArray followed by JoinNumbers… (Or any other operation you would like to do, it's not quite clear from your question!)
Message 2 of 14
(10,158 Views)
Thank you for your reply, I edited my question adding some more detail and a picture.
Message 3 of 14
(10,149 Views)
It would help us if you gave a very clear example of the data coming in and what you want as an output.  Doing it with a VI would be the best (set the example data values as the default before saving).
GCentral
Message 4 of 14
(10,133 Views)
GerdW already made this point, but here you have it illustrated in vi snippets.
Message 5 of 14
(10,118 Views)
Hmm, I have a question considering your earlier question and this one, the strings you are reading, which do they look more like?
A) "0F AA 12 45 E4"
B) " !51 @#$@% ar12 12355"
Jon D
Certified LabVIEW Developer.
Message 6 of 14
(10,092 Views)
Thank you for the visual, that makes a lot of sense!
It almost works, my first 2 elements are 49, and 100, but when they get combined it becomes 12645... but I want it to be "49100" any ideas?
Thank you.
Message 7 of 14
(10,084 Views)
Please help us help you by posting a VI with your data in it.
"100" hex will not fit in a U8 so please post a vi with your data and what you think it should be.
Ben
Message 8 of 14
(10,079 Views)
The strings look like B)
Message 9 of 14
(10,071 Views)
Your various posts are not self consistant.
Post a VI wi the data you have and the results you expect.
Our assistance is limited by your willingness to cooperate.
Ben
Message 10 of 14
(10,064 Views)
