Conditional array sum
Hi there,
I'm very new to labview so bear with me.
I would like to walk through the elements of an array that meet certain conditions and sum them, until the condition is not met.  I would then like to take that sum and build a new array, the second element being the element that did not meet the condition.  I would then like to continue from where I left off, but starting a new summation that would then be appended to my new array until the condition is not met, and so on...
For example
Given the array:
0.5
0.5
0.5
4
0.5
0.5
0.5
4
...would like to output..
1.5
4
1.5
4
I've been able to get a summation until the condition is not met using a while loop, however, I can't figure out how to continue from where I left off in the array.
If anyone can give me a point in the right direction that would be appreciated.
Message 1 of 11
(6,269 Views)
It more convenient if you show us what you have done so far. As code NOT a picture. It is more easy to solve your problem this way. And your problem is not difficult to solve 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 11
(6,266 Views)
Here is one example I have.  I didn't include any code before because I've tried so many different things and I would rather do it properly than try to try and "fix" my version.
This code sums everything in the array meeting the condition, but it's not correct.
Message 3 of 11
(6,257 Views)
This should do it.  Interesting exercize.
Message Edited by Jeff Bohrer on 07-29-2009 01:03 PM
Message 4 of 11
(6,254 Views)
Accepted by topic author Geir58
Try this:
You still need to deal with the condition where the last element does not meet the condition, but that would be easy to fix. Try it. 🙂
Message Edited by altenbach on 07-29-2009 11:32 AM
Message 5 of 11
(6,237 Views)
Thank you,
I've been having a hard time understanding shift registers but this is exactly what I needed.
Message 6 of 11
(6,223 Views)
Be careful, as I mentioned, you still need to tweak it a bit.
  1. Return empty array if input is empty
  2. Work correctly if first element is not a match
  3. Work correctly if last elements are a match.
Here's one possible solution. Modify as needed.
Message 7 of 11
(6,194 Views)
Thats why it was so interesting to solve.  see my previous post.  The code shown handels the above mentioned cases
Message 8 of 11
(6,189 Views)
Of course if the arrays are large, you don't want to grow arrays inside loops. Here's an in-place solution that is probably better if performance is an issue.
(please verify correct operation). 😄
Message 9 of 11
(6,176 Views)
correct operation!
I've never even looked at that pallet before
(in 8 years)  Thanks for the eye opener!
Message 10 of 11
(6,164 Views)
