Configuration of RTSI_ref_clk for FPGA compilation
Hi All,
 I have a target VI which has a HDL Node inside it. I configured the RTSI_ref_clk using the "Compile for a single frequency" option and
generated the bitfile and the functionality of the bit file is as expected.
 Now, I want to generate a bitfile which can work for a range of frequencies. For this, I configured the RTSI_ref_clk using the
"Compile for a range of frequencies" option. The generic variable named Clock Frequency of the HDL Node is configured to a fixed frequency irrespective
of the range provided. And when CheckSyntax is done, the following error is displayed.
ERROR:HDLParsers:414 - "C:/DOCUME~1/Test-01/LOCALS~1/Temp/WBM_Tx.vhd" Line 10. The integer value of 4293967296 is greater than integer'high
Can you provide any help to resolve this issue. Please its urgent
Raj
(3,225 Views)
Hi all,
   Did anyone tried using the "Compile for range of frequencies" option in RTSI_ref_clk properties window?(Under Clocks of FPGA Target - PXIe-5641R)
(3,173 Views)
Can you please specify about the Software environment and the corresponding versions you are working with?
(3,160 Views)
Labview2009 with FPGA Module.
PXIe-5641R IF RIO Transceiver - H/W
(3,156 Views)
