Configure simulated device in MAX
Hi All,
I am currently trying to use an executable to control some hardware. The .exe has some inbuilt safety limits - it reads some sensors using Digital IO - and if these are in the incorrect state my operation aborts. This works perfectly when I have the system I am working with correctly configured. However we are working on a second system which has the same core hardware but none of the sensors (or the Digitial IO card to read them) fitted.
Ideally I would like to fool the code into seeing that the DAQ card is present and I have done this through creating a simulated device in MAX. However once I shut down MAX and start my code all the Digital IO values flicker on and off. When I run a test panel with my VI already running there is a resource conflict. Has anyone got an idea how I can get the simulated DAQ card to simulate a constant signal of 0V or 5V once MAX is closed?
Thanks for your help,
Dave
(3,829 Views)
Accepted by topic author DeltaJ
You don't have the ability to set what the simulated board will read. If I recall, it just counts from 00-FF for a port.
(3,824 Views)
Ah that's a pity - I might wander over to the idea exchange to suggest is as I think it would be useful!
Thank you for the quick reply,
Dave
(3,819 Views)
The idea is up on the DAQ idea exchange board now! Please vote if you think it is worthwhile,
Dave
(3,815 Views)
