micos pmc-100 piezo
Hi there, for this piezo , I need to know how much in length it moves at high speed (HSPD = 1000000). Is there like a rate it moves (like mm/s or something) like that? Thanks
(3,785 Views)
i checked the manual, is it 2 mm/s?
(3,784 Views)
Hello j49sun,
I am assuming you are asking about the device listed on the following link, is this correct?
http://www.micosusa.com/product/prodDetail.cfm?firstlevel=2&sublevel=22&prodid=163
The device that you are driving with the motor controller is also an important consideration; what device will you be driving with this controller.
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
(3,774 Views)
Hello Eric, I believe the piezo stage I am using is a PP-30.
(3,752 Views)
The PP-30 manual list the maximum speed as 2mm/s; I am unable to find the manual for the PMC-100 at the moment but the maximum speed will be limited to the smaller of the 2 devices (Driver limit or Piezo Stage). You may have to check with the manufacture of the 2 devices to confirm.
Eric
Eric Liauw
(3,736 Views)
