Configuring 9475 CDAQ Digital Output Card
I am using CDAQ Digital Output 9475 Card.Is it possible to create a common task for all Lines in a single event.Or every line or channel has to be addressed individually. like in PXI relay card , a task is once initialized and the multiple relay can be configured .
(3,555 Views)
You can group multiple channels in the same task as long as they are the same I/O type.
'Tasks in NI-DAQmx'
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/tasksnidaqmx.html
'Learn 10 Functions in NI-DAQmx and Handle 80% of Your Data Acquiistion Applications'
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
(3,496 Views)
Hi Jimy,
you should be able to select a "port" instead of "lines" when creating your DAQmx output task…
(3,491 Views)
