Configuring Multiple Counter Input channels through SIT
Thank you for your help .In fact I succed to develop with SIT manager an application with a lot of analag Inputs ( with changing the model Name IO.llb)  but when trying developping the same thing with a digital input line and a digital output line , I have the error 66.. the problem is with TCP/IP commincation. have you an idea about this ERROR  . The example is enclosed .Thanks  .
Message Edité par MAM_80 le 04-03-2007 04:24 PM
Message 11 of 13
(1,034 Views)
In regards to the error you are receiving, I'd first suggest making sure that you do not have two processes trying to access port 6011 (SIT port) at the same time.
Also, you might want to review this KB. Even though it might not address your issue explicitly, the suggestions it makes may be analagous when using SIT server.
Hope this helps.
Emilie Kopp | Applications Engineer | National Instruments
Message 12 of 13
(1,020 Views)
hi Emilie,
  Sorry for late response. Right now i am at client place, there i dont have LAbview setup.
  Once i back from there, i can work on that and let u know about that.
Thanks  for u r response
naveen
Message 13 of 13
(1,016 Views)
