Configuring Simulated Hardware for Online Training
I am attempting to learn LabVIEW NXG through the online training. In the first
or second module there is a segment called "Configuring Simulated Hardware
Demonstration".  Here it asks you to click on the "HARDWARE" tab to configure
the simulated hardware.  However there is no HARDWARE tab on my screen.  I
suspect this is because I don't actually have any NI hardware connected to my
PC.  Unfortunately based on my project's schedule it will probably be quite a
while before I do have any hardware connected.
Is there some way for me to enable the HARDWARE tab (or otherwise configure the
simulated hardware) in this circumstance so that I can do the online training
with the simulated hardware?
(2,902 Views)
I don't have NXG personally but if you open NI-MAX you can set up simulated instruments that LabVIEW can use there, and I assume NXG shares the same instrument pool.
Try opening NI-MAX, then right-click "Devices and interfaces", then when it asks you what to add choose "Simulated NI-DAQmx Device or Modular Instrument" and go from there.  Then see if the needed option appears.
(2,892 Views)
