Problems communicating with motor using LabVIEW
Hi
  I have three motorized actuators that are connected to the computer via USB through the TDC001 controller. I am trying to control the motors using the ActiveX control through LabVIEW. When I use the APT software and even another python code that communicates with the motors, they are recognized and can be operated from the computer. However, when I try to establish a connection through the LabVIEW code, it fails, and I get return code 10109 (basically meaning the device is not connected). Can anyone help on this?
(2,878 Views)
Did you create these VI's yourself, or were they provided by the manufacturer?
B. Poteet
(2,817 Views)
