Configuring remote front panel
I'm trying to configure remote Front Panel on Labview 2016, on cRIO 9030.
That's the configuration of my cRIO in project.
Next I'm opening my program, and set it's configuration
After that I'm going to Web Publishing Tool
And start new Real Time application
After that when I type in browser 192.168.1.50:80 Web based cofiguration is opening, but when I try to type 192.168.1.50:8000/HMI.html   It shows that it cannot show this site. What is more, when i try to open 192.168.1.50:8000 it shows me error: Przechwytywanie7.PNG
Can anybody tell me what am I doing wrong?
(5,146 Views)
Really nobody ever did It before? Guys I'm asking you for any advice 🙂
(5,091 Views)
Accepted by wojtek432
Hello wojtek432,
Did you try to follow step-by-step instructions in this knowledgebase: Configuring Remote Front Panels on a Real-Time Target ?
Are you sure your Web Server is installed properly on the cRIO?
You can try also the basic troubleshooting common for most Web applications:
Is there any firewall or intelligent antivirus on the way between cRIO and browser?
Did you try a different browser?
If none of these helps, let us know again and we can try to continue troubleshooting.
(5,058 Views)
Naturally problem was on the side of my firewall. When I unblocked labview it started to work, but there is one more problem. When I start Web Publishing tool, and uncheck "Request control[...]", then It won't find my html file althougt it really exists in expected directory on cRIO.
(5,053 Views)
I am happy that your problem has been resolved. You can mark the answer as the solution.
Also, thank you for follow up question, but please create a new topic with a new question in order to make the forum more readable for people with similar problem.
Thank you
(5,040 Views)
