Conflicting library versions when deploying a VI to a PXI target
Hi fellow developers,
Using LabVIEW 2025 Q3 (64-bit) with the RT Module.
When running/deploying my VI to my PXI target, I systematically get conflict dialogs about libraries on the target not matching their version in the project:
It seems the conflicting items all are NI libraries:
XDNodeRunTimeDep.lvlib
NI_FileType.lvlib
LabVIEWSMTPClient.lvlib
NI_MAPro.lvlib
NI_LVConfig.lvlib
NI_Data Type.lvlib
NI_PackedLibraryUtility.lvlib
NI_SystemLogging.lvlib
NI_Gmath.lvlib
NI_Matrix.lvlib
Questions:
1. Why does it happen on NI libraries? I obviously did not modify them, whereas my own libraries/classes are frequently modified and they do not seem to have this issue.
2. Why does it cause a conflict? Can't LabVIEW always overwrite the version on the target with the one from the project? Nothing is running on the target except my VI.
According to this discussion:
https://forums.ni.com/t5/LabVIEW/The-version-of-this-library-downloaded-on-the-target-does-not/td-p/...
I could just hit "Apply" and not bother, but it happens systematically.
Any idea of what is happening?
Crosspost on the #rt Discord.
Raphaël.
(201 Views)
Could it possibly be related to this deployment issue about unclear error messages?
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
(180 Views)
Hi Joerg,
That may be it, I frequently run my VIs on "My Computer" first for testing, then on the actual PXI target. I also have some VI Scripting code in "My Computer" that may reference or generate part of the RT code.
I know the workaround of using only one target per project, but I feel this is just too restrictive!
LabVIEW allows to create multi-target projects, which is really convenient for testing the code, so I expect to be able to use this possibility.
I wonder how such a big issue is still unresolved?
How can I test my RT code on the PC? I am not talking about unit tests, just executing the RT code on the PC to partly debug it.
Having 2 projects side by side feels silly...
Raphaël.
(153 Views)
