Confused about and IVI versus plug and play instrument drivers
I'm just getting in to LabVIEW and see that when I go to download instrument drivers, there are several listings.  One is Plug and Play and the other is typically IVI.  What is the difference?  So far I've been through the Lesson #1 and Lesson #2 Basic Developer courses, but we haven't touched on the use of downloaded drivers.
(4,344 Views)
Accepted by djpritchard
IVI: Interchangeable Virtual Instrument. Using this software layer enables the developer to work with a "generic instrument" independend of the manufacturer (e.g. Agilent DMM vx. NI DMM).
Plug'n'Play driver: The driver for the very instance of an instrument, needed for the OS to identify and drive the instrument. The driver is device specific.
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,339 Views)
You can also read Types of Instrument Drivers, though Norbert pretty much summed up the highlights.
(4,335 Views)
