Connect Get Waveform Components to Read TDMS
Dear All,
I met a problem when I tried to read the dt of waveform data from TDMS. The help shows "You have connected two terminals of different types". The type of the source (Read TDMS function) is 1D array of waveform, while the type of sink (Get Waveform Components function). I tried to use Index Array but failed. Could anyone tell me how to solve this connection problem, please? Thank you so much!
By the way, if I connect Get Waveform Components to WAV generation vi like Sine wave.vi,
(1,840 Views)
Accepted by topic author PatrikLiu
Hi Patrik,
for me the IndexArray works as expected:
(1,820 Views)
Yes, it is. Now it works. Maybe I made some mistake before. Thank you so much!
(1,805 Views)
