ERROR "L'erreur 7 s'est produite à : Open File+.vi:Open File"
i created an executable for a project, it was created correctly, also the installation is done; but after lauching *.exe, i have an error wich occurs;
photo attached.
Best Regards,
Aymane
Message 1 of 10
(2,444 Views)
Hi Aymane,
error 7 is "file not found": did you check if the file path is valid? (Did you check that also in the executable?)
Generic advice as you didn't attach any code: Don't use "Current VI's path" inside the exe!
Message 2 of 10
(2,439 Views)
Hi Gred,
i have the same project running on the same machine with the file path, but it doesn't wotk with the insttaler/.exe;
i didn't understand your msg ''Don't use "Current VI's path" inside the exe!"!
Best Regards,
Aymane
Message 3 of 10
(2,421 Views)
He means don't use this node:
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 4 of 10
(2,411 Views)
Hi Amyane,
inside an executable the "Current VI's path" contains one more folder level due to the executable: this will bite you when trying to build path to files!
Use the "Application directory" constant instead!
Message 5 of 10
(2,401 Views)
Should be changed by application directory? and after that you have recreate the installer?
Message 6 of 10
(2,398 Views)
Hi Aymane,
Yes.
And yes: when you change the code then you need to recompile…
(Don't forget to test/debug your code in between those two steps!)
Message 7 of 10
(2,381 Views)
Hi Gerd,
i tested to replace Current VI's path with Application directory, but it doesn't work in test/debug?
Best Regards,
Aymane
Message 8 of 10
(2,266 Views)
Hi Aymane,
which file do you are try to access? What is the full path of that file?
Which path do you create within your VI/executable?
Did you compare both?
Message 9 of 10
(2,259 Views)
Hi Gerd,
Yes, after comparing the two methode, a directory name was missing in the path;
best Regards,
Aymane
Message 10 of 10
(2,245 Views)
