Connect OMRON PLC CP1E/NA (hostlink) to LabView via Serial Cable
I am trying to connect my PLC (Omron CP1E-NA) to LabView. The PLC supports Hostlink when talking to PC.
I have LabView Full development environment and DSC Module installed. Other modules are avaiable if needed.
My project is to connect this PLC to LabView so that I can develop control interface via LabView. The connection between PLC and PC is RS232 cable.
I am not sure how to configure LabView in order to enable communication with PLC.
Any possible connection methods are welcome. My work is somewhat urgent, so I look forward to your help very much.
Thank you all for your kindly help.
Wei
Message 1 of 11
(7,897 Views)
Is it possible to test the connection from PLC to PC using the PLC software?  This way you can verify the connection, and then connect with LabVIEW or even better use some manual commands with MAX.
Mark Ramsdale
Message 2 of 11
(7,889 Views)
PLC's software can communicate with the PLC only via USB. It can connect to a control interface development software via serial cable.
Message 3 of 11
(7,883 Views)
As you mentioned MAX, what should I do with manual commands? Thank you.
Message 4 of 11
(7,881 Views)
I tried to configure my PLC in MAX. I connected PLC with PC via serial cable. In MAX, it says it works properly. What's the next step? Thanks.
Message 5 of 11
(7,879 Views)
hi , i had been trying to establish communication with NI WLS 9163 but not been possible , i used following setting  in My plc
port numner - 31415
ip address of module ,
or else let me know what commands i can send to receive response from ni wls 9163 through a third party application ie like my plc
Message 6 of 11
(7,751 Views)
Hello Mateen,
I believe that it would be better if you created a new thread for this question. The original thread is attempting communication via rs-232 and your question is related to wireless configuration. Hopefully in a new thread you will have a larger community response relating to this question.
Joel
Message 7 of 11
(7,733 Views)
howdo i create a new post/forum thread
Message 8 of 11
(7,730 Views)
Hello Mateen,
Here is a forum thread that describes the steps to posting:
http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/Quick-Introduction-to-the-Forums-for-New-Us...
I hope you have success finding solutions using the NI Discussion forum.
Joel
Message 9 of 11
(7,713 Views)
Dears,
i am also having omron PLC CP1E -NA module, and i would like purchase the labview 2013 development module.
before that i would like to get your opinion for the utilities.
Can I interface with the PlC via Rs232c ,
kindly advice to me.
Regards
R kumarsamy
Message 10 of 11
(7,136 Views)
