Connect multiple cluster to one graph
How do i connect the highligthed portion (refer to attached file) into a graph?
(3,680 Views)
Hi DIP,
quick fix: use BuildArray (in concatenation mode) instead of BundleCluster!
Better fix: get rid of all those DDT wires and ExpressVIs…
(3,657 Views)
Hi Dip1080,
Attached, a solution for you... Just build an array in concatenation mode  !
edit : as GerdW explained 🙂
BR
Vincent
(3,650 Views)
Hi Vincent
Do u mind to screenshot and send me the in pic format instead ? I cannot open the file in labview 2012 ver.
(3,586 Views)
Hi DIP,
you only need to replace your Bundle function by BuildArray as described above!
(3,562 Views)
I advice you to do tutorials about how to use LabVIEW ....
BR,
Vincent
(3,560 Views)
(3,546 Views)
