modbus write multiple registers wrong version
I'm using NI Modbus.llb, found on the NI site somewhere...
Now I found broken wires in calling vi because of MB Serial Master Query Write Multiple Registers (poly).vi has one output to less (probably the written content, read afterwards... to check...)
Where can I find the proper MB Serial Master Query Write Multiple Registers (poly).vi ?
thanks
(3,789 Views)
Sounds like you use that one here:
http://www.ni.com/example/29756/en/
My recommendation: Dowload & install again, I for myself never had problems with broken wires with that lib.
Regards, Jens
Kudos are welcome...
(3,780 Views)
(3,776 Views)
Accepted by topic author kdCMC
it can also be that the previous guys modified the NI Modbus function....
(3,773 Views)
