I need to develop a VI that can be used on a FieldPoint, so that the FIeldPoint can connect to an ISP via a modem and send a file across the internet to an FTP server. Does anyone know if this is possible and if so how?
I assume you're talking about the FieldPoint network module that runs LV-RT? If so the problem I see is one of memory. You have to write a program including the FTP client that can all fit into the module's flash. It should be do-able (in theory at least) just be very careful about adding anything to the code that you absolutely, positively don't need.
Mike...
Certified Professional Instructor Certified LabVIEW Architect LabVIEW Champion
