Connecting Delta Loadcell module(dvp02lc) to LabVIEW using Modbus
I'm just trying to read some loadcell data using Delta loadcell module with part number code : dvp02lc.
This module supports Modbus ASCII/ RTU on both RS232 and RS485. At my first try I decided to communicate with this module using its RS232 port.
I'm using LabVIEW 2012 with DSC toolkit. I followed the tutorial provided here step by step. but I can't get it work.
I'm a little dizzy right now. I don't know how I can convert the register address provided in the module datasheet to modbus register addresses.
two following pictures show the datasheet register address. and different register address configurations I used in labview to connect to the device with no chance of success!
What am I doing wrong?
Message 1 of 1
(3,912 Views)
