DAQmx Trigger Minimum
 I have a  program which uses the DAQmx Trigger function and I appear to have found a lower limit for Start:Analog Edge:Level.  When my level is set at 35mV and below the vi does not run, above 35mV and it does.  I am using a NI PCI-6132 S Series card for the system.  I was hoping to set the trigger level at values as low as 10 mV.
(3,254 Views)
Would it be possible for you to post either a screen shot of your code or your actual code?
Matt G.
Product Manager
(3,211 Views)
