Connecting MX100 data to LabVIEW
Hello, I want to display the real-time temperature recording on LabVIEW
through YOKOGAWA MX100
However I installed the DAQmx driver, and it still didn't work.
Then It seems that I should download the driver package for MX100 from
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E79B10986F222E30E0440021287E65...
but I don't know how could I deal with the file...
Is there anyone who know about this?
(3,865 Views)
It looks like you will also need NI-VISA 4.0. You should also extract the folder for the driver to location: C:\Program Files (x86)\National Instruments\LabVIEW 2016\instr.lib as it's explained in this document. http://www.ni.com/devzone/idnet/inetinst.htm
After doing this, you should then be able to reference the libraries for this driver in LabVIEW.
Andrew B.
Application Engineer
National Instruments.
http://www.ni.com/support
(3,832 Views)
