Darren's Occasional Nugget 05/13/2014
Having the ability to generate PDF files from LabVIEW is a rather common requestI recently discovered a very simple way to generate PDFs from LabVIEW with a quick modification to some existing NI software. First, you must have the following products installed:
  • LabVIEW 2009 or later
  • LabVIEW Report Generation Toolkit for Microsoft Office 2009 or later
  • Microsoft Word 2007 or later
If you have all of this software, then open vi.lib\addons\_office\_wordsub.llb\Word_Save_Document.vi and make the following modification:
More specifically, add the ".pdf" case with a value of "17" inside. Now, if you wire the path to a PDF file to the Save Report to File.vi for a Word report, then a PDF file will be generated:
We will try to get this change into the Report Generation Toolkit in a future version. I realize that this trick doesn't solve all the use cases (like PDF generation on a system without Word installed), but I'm hoping that it can help out some people today.
Message 1 of 11
(13,265 Views)
Hello Darren,
I wonder if this tricks works for a Excel report as well.
UliB
Message 2 of 11
(13,170 Views)
Or if you don't have Report Generation Toolkit for Microsoft Office (which, I think, is not so cheap) you can just simply install PDF Creator and use it as a printer in Easy Text Report.vi 🙂 Solution with some faults but cheaper...
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 3 of 11
(13,073 Views)
Yes, I was able to get it to work with Excel with a similar edit to vi.lib\addons\_office\_exclsub.llb\Excel_Save_Workbook.vi. Some things to keep in mind:
  • For Excel 2010 and later, the numeric value inside the ".pdf" case would be 57.
  • For Excel 2007, I think you would need to first install the Microsoft Save as PDF or XPS add-in.
  • For Excel 2007, I think the numeric value inside the ".pdf" case would be -1.
I'm not 100% sure about the Excel 2007 scenario, because I didn't have a test machine available to try it out. But for Excel 2010 and later, it definitely works.
Message 4 of 11
(13,046 Views)
run this vi,i have an error code 1498,how to solve it
Message 5 of 11
(12,944 Views)
How does this have anything to do with this thread?  Go to the main menu of the LabVIEW forum and click on the "New Message" button located to the left, just above the list of topics.
Bill
CLD
(Mid-Level minion.)
Message 6 of 11
(12,835 Views)
Have you installed the Report Generation Toolkit?
George Zou
Message 7 of 11
(12,795 Views)
Seeing as the RGT is LVOOP based, technically you could just extend it without having to modify existing toolkit funcitonality, which would then break if someone loaded the code on a different machine without this instance of the "save" in vi.lib
Message 8 of 11
(12,746 Views)
FYI to anyone still following this thread, I'm happy to announce that these changes have made it into the Report Generation Toolkit for LabVIEW 2015 and later.
Message 9 of 11
(9,525 Views)
Yes great, thanks a million Darren.  I am using this capability to save excel pdf files using the RGT.  My only problem is that it does not seem to save multipage workbooks.  Is there a workaround for this?
Message 10 of 11
(7,907 Views)
