Connecting Simulink Circuit to LABview Controller
I'm trying to use my LABview VI to control switches in a Simulink model. I'm not sure how to accomplish this task, but right now I'm trying to establish a connection between the two.
I have LABview 2015 and MATLAB 2011.
After Googling how to connect a Simulink model to LABVIEW, I found the following methods:
1. Using the Model Interface Tool (MIT)
2. Using the Controls and Simulation Toolkit to convert a Simulation Model into LABVIEW
1. I downloaded MIT and Veristrand and followed the steps in this link: https://www.ni.com/docs/en-US/bundle/labview-model-interface-toolkit-api-ref/page/vsmithelp/mit_conv...
But I'm not sure where to go from there.  Most tutorials I found were using the SIT
2. The Simulink components aren't recognized in LABVIEW and are just empty boxes.
Question: What's the best way to connect the Simulink model with LABview?
(8,615 Views)
Accepted by oreo22
This seems closely related to this one.
Both methods can be used but both require a few considerations.
For the Model interface Toolkit you need to mind what functions you use. Please take a look at this.
"In the Simulink software, you can convert models that use only a fixed step-size ordinary differential equation (ODE) solver into compiled models. Additionally, you must turn off data logging in the Simulink application software."
 Please refer to the following as well.
https://www.ni.com/docs/en-US/bundle/labview-model-interface-toolkit-api-ref/page/vsmithelp/mit_mode...
(same I linked above)
(this is the one you linked yourself, just want to bring that the model needs to be a dll to work with the Model Interface Toolkit)
http://forums.ni.com/t5/LabVIEW/importing-matlab-model-file-to-labview/td-p/883625
(the post mentions the "SIT" which is not the Model Interface Toolkit)
The last one brings something about the Control Design & Simulation method: the model needs to be an mdl file in order for the Simulation Model Converter to work.
http://www.ni.com/white-paper/11281/en/
(this link is from LabVIEW 2012, but it is still valid on later versions)
https://zone.ni.com/reference/en-XX/help/371894G-01/lvsim/sim_simtrans/
Hope it helps.
MATLAB® and Simulink® are registered trademarks of The MathWorks, Inc.
Camilo V.
(8,578 Views)
Yes, the posts are related. Thanks so much for the help and links!
Out of curiosity,  I switched to the MIT method because when I tried to import .mdl into the Simulation Model Converter, I get the result in the image.
SimPowerSystems aren't on the unsupported Simulink blocks  list, so am I doing something wrong or are they unsupported?
(8,557 Views)
Glad the information helps.
About the error, I cannot be sure without knowing what the model uses, but there are some partially supported and some totally unsupported blocks from Simulink®. My first though was that maybe some of those are the cause of the Simulation Model Converter to fail. Please find more details information here.
Camilo V.
(8,548 Views)
