Connecting amplifier transducer to NI USB 6212
Hi, im totally new to using the datalogger, i would be very thankful if someone could help.
Im looking to connect an amplifier transducer:
https://www.fylde.com/wp-content/uploads/2018/03/FE379TA.pdf
to the NI USB-6212. There is only a single output from the transducer (with a BC connection), i don't understand which input on the logger shouldi connect the wire to?
Thanks so much.
(2,208 Views)
Find an engineer who can understand what the amplifier transducer does, what its output is (there's not a lot of information in the PDF you attached, but it does have a ±10v output, possibly over a BNC which I'm guessing is what you called a "BC Connection").  He (or she) might be able to explain what to do with the USB 6212 and how that has anything to do with "the datalogger".
Bob Schor
(2,174 Views)
