Connection Between Sensors and cRio
I have a temperature sensor with this wiring information. How should I connect it to cRio Input Module, which require both positive side and negative side connection.
In addition to this temperature sensor, I don't know how to connect this Hall effect sensor to cRio, either.
(2,492 Views)
Hi niukasu,
Which C series module are you planning to use with this sensor?
(2,457 Views)
