09-24-2013 03:49 PM - edited 09-24-2013 03:53 PM
I have a temperature sensor with this wiring information. How should I connect it to cRio Input Module, which require both positive side and negative side connection.
In addition to this temperature sensor, I don't know how to connect this Hall effect sensor to cRio, either.
09-25-2013 08:11 AM
Hi niukasu,
Which C series module are you planning to use with this sensor?
